Sovtek MIG50: 511V plate voltage. Which "dark" 6L6 tube?
Harold
Post by Harold » Sat Nov 17, 2012 7:17 am
I recently bought a 90's Sovtek MIG50 with the original tubes in it. After replacing the poweramp wiring (was a real mess!) and all pots, I added pre PI master volume and fitted the preamp with JJ's.
The amp is still very bright and lacking (sub)lows. I guess that this might be due to the 20+ year old Sovtek 5881's (6P3S-e with the "coin" base). I even clipped the bright caps, but that didn't fix the brightness.
Schematic: http://www.el34world.com/charts/Schemat ... G50-60.pdf" onclick="window.open(this.href);return false;
(My MIG has 100nF PI coupling caps and a few minor other differences from this schematic)
I was recommended the JJ 6l6GC, but the datasheet tells me that the tube might not be happy running on the MIG's 511VDC plate voltage.
Any other recommendations for a fat, "dark" 6l6 that can handle a lot of voltage? :help:
Gibson SG Jr > DP209 > Ross Distortion > JMP 2203, 2204 or 1987x > 1960TV
TANK86 - Instrumental sludge metal!
DIY-Layout.com - Online stripboards!
Tremblayamps
Re: Sovtek MIG50: 511V plate voltage. Which "dark" 6L6 tube?
Post by Tremblayamps » Mon May 27, 2013 4:03 pm
I threw KT-88's in a marshall 2204 and it gave it fat low end. You can try both 6550 and KT-88's. You will have to mod the Bias section most likely to handle the 88's. It would be r27 on the schematic (10k). After the I the put the 88's in I would never go back to 34's in that amp.
-------------------------------------------------------------------------------------------------------------------------------------------------------Tremblay Amps
https://www.facebook.com/TremblayAmps" onclick="window.open(this.href);return false;
Harold
Post by Harold » Mon May 27, 2013 4:24 pm
Well, I've gone a slightly other path with my Sovtek Mig50 ;)
  • Put in a IGOT-JMP50 output transformer
  • Switchable V2a cathode bypass: none, 680nF and 220uF
  • Switchable fixed resonance: 2n2
  • Changed the 47nF in the tonestack to 22nF
  • NFR to 100k (instead of 39k)
  • Internal jumpering of both channels
  • And ... JJ 6l6GC's ;)
Of this list, the output transformer made the biggest difference! With the fixed resonance engaged, I have to roll down the bass to at least 2-3, so that's a nice "bedroom level mod".
Tremblayamps
Post by Tremblayamps » Mon May 27, 2013 5:17 pm
What are your thought on the ig transformers. I'm in the midst of a soldano project and im trying to find the best transformers and the ig transformers came up but i haven't reviewed them to much yet
Harold
Post by Harold » Tue May 28, 2013 8:52 am
Tremblayamps wrote:What are your thought on the ig transformers. I'm in the midst of a soldano project and im trying to find the best transformers and the ig transformers came up but i haven't reviewed them to much yet
Well, Ingo has had some difficulties manufaturing them due to personal reasons but he is up to speed now and building a nice stock. His new webstore also doen't allow items to be sold which aren't in stock.
I bought two "Marshall" 50W OT's and one 100W. I've only used one 50W to replace the stock OT in my Sovtek MIG50 and it's a helluva difference! Loads of clear lows and way less "barking" aka annoying high/mids.
I have a couple of original 2203 and 2204's which I'm thinking about upgrading with IG transformers since they're kinda cheap ... :scratch:
There might also be another MIG50 on it's way ;)
